A step-by-step look at how AI agents plan, act, and iterate autonomously — and what that means for the way teams get work done.
What is an agentic workflow?
Most AI tools answer questions. Agentic workflows take action.
An agentic workflow is a process where AI agents autonomously plan, execute, and iterate on multi-step tasks to reach a defined goal. Rather than following a preset script, the agent decides the script as it goes — using whatever tools and data are available, and adjusting based on results.
The clearest way to see the difference is in the loop. A chatbot responds and waits. An agent responds, evaluates the result, decides what to do next, acts again, and keeps going until the task is complete.
Consider a contract question. A chatbot answers, "Summarize this contract." An agentic workflow reads the contract, flags the renewal clause, routes the approval request, logs the outcome in your CRM, and notifies the account team — all from one trigger.
That's also what separates agentic workflows from traditional automation. Rule-based automation follows decision trees: if X, do Y. It covers a fixed set of conditions. Agentic workflows reason about conditions that weren't anticipated at build time, which is why teams are using them to cover ground that automation never could.
The core components of an agentic workflow
Every agentic workflow runs on the same set of building blocks.
The AI agent is the reasoning engine — typically a large language model (LLM) — that interprets the goal, decides what to do next, and evaluates whether the last step worked. It goes beyond generating content to directing its own action. The agents creating the most durable outcomes aren't just working for individuals; they're coordinating work across teams.
Integrations and surfaces are what let the agent actually do things: call an API, run a database query, send a notification, update a record. Without tools to act with and surfaces to act on, an agent can reason but can't produce.
Memory comes in two forms. Short-term memory is the context window — what the agent knows about the current task right now. Long-term memory is a persistent data store the agent reads from and writes to across sessions, so it doesn't start from scratch every time. When memory is codified in a shared system, knowledge compounds across teams rather than resetting with each session.
Triggers and goals define when a workflow starts and what "done" looks like. A trigger might be a form submission, a scheduled time, or an event in another system. A goal tells the agent what success looks like so it knows when to stop.
A shared data layer is where humans and agents read from and write to together. This is what makes agentic work auditable, collaborative, and recoverable. It's also what most early deployments miss. The agent's output needs to land somewhere structured and visible — not disappear into a chat thread.
How an agentic workflow runs, step by step
Here's a concrete walkthrough of what happens when an agentic workflow fires.
1. A trigger fires. A user submits a form, a scheduled job runs, or an event in another system kicks things off.
2. The agent receives a goal and relevant context. It knows what it's supposed to accomplish and has access to the data and tools it needs.
3. The agent plans a sequence of steps. It decides which tools to call, which data to look up, and what order to execute them in. This plan can change as results come in.
4. Each step executes, and the agent evaluates the result. Did the API call succeed? Did the retrieved data match expectations? The agent uses the result to decide what to do next.
5. The agent loops, adapts, or escalates. If a step fails or the result is ambiguous, the agent tries a different approach — or flags the task for human review if it's outside its confidence.
6. Output is written back to a shared system of record. The final result — a decision, a document, an update — lands somewhere structured, visible, and inspectable. Because it's codified in a shared system, work and knowledge persist across teams and sessions.
What makes an agentic workflow enterprise-ready?
A capable model is a starting point, not a deployment plan. Enterprise use requires several things working together.
Shared, structured data. Agent actions need to read from and write to a system of record that other humans and systems can see. Chat history is a log, not a data layer. If your agents are writing results into a chat thread, you don't have a shared data layer yet.
Governance. Permissions that control what the agent can access, audit logs that capture every action and the reasoning behind it, and approval gates for decisions that require human sign-off. When something goes wrong, you need to be able to reconstruct exactly what happened.
Human-in-the-loop escalation paths. Defined conditions under which the agent pauses and asks a human, rather than proceeding with low confidence or failing silently. This isn't a workaround for a weak model — it's good system design for any task with real stakes.
Model and tool agnosticism. Enterprise agentic workflows shouldn't be locked to a single LLM or vendor. As models improve, you need to be able to swap them without rebuilding your processes from scratch.
Durable, inspectable workflows. Workflow state should survive a browser close, a model timeout, or a team member's absence. Durability is a governance requirement, not just a technical nicety.
Real-world agentic workflow examples
Marketing campaign intake and routing. An agent collects brief details from a form, checks against brand guidelines, routes to the right team, and creates the tracking record without a coordinator in the middle.
Contract review and approval. An agent reads an uploaded contract, flags non-standard clauses, compares against a template, and routes to legal or a manager based on risk level.
Recruiting pipeline management. An agent screens incoming applications against a job description, schedules interviews for qualified candidates, and updates the applicant tracking system (ATS) without coordinator involvement at each step.
Operational data updates across teams. An agent monitors a trigger condition (a deal closes, a ticket resolves, an order ships), updates records across connected systems, and notifies the relevant stakeholders.
In each case, the agent isn't replacing judgment — it's handling the coordination work that doesn't require it, so human attention can go where it makes more impact.
How to build agentic workflows without an engineering team
Most agentic workflows don't require custom code to get started, but they do require the right foundation.
No-code and low-code platforms make it possible for operations and business teams to configure agents, define goals, connect tools, and set escalation rules without writing a line of code.
A relational data layer is what separates durable agentic workflows from one-off automations. Agents need to read structured data, write results back, and hand off to humans — which requires a shared, queryable data foundation, like Airtable, not a collection of chat logs.
Start with one workflow, then scale. Teams that succeed with agentic AI typically begin with a single high-friction process: one that has clear inputs, a known goal, and existing data. Picking the right first workflow matters more than picking the best model.
Common pitfalls to avoid
Agents operating on stale or siloed data. If the agent's data isn't current and connected to the systems that matter, it will make confident decisions based on wrong information. Data freshness is an architectural requirement, not something you can patch later.
Missing governance. When something goes wrong — and it will — you need to know what the agent did, in what order, and why. Without logging at the action level, debugging an agentic workflow is close to impossible.
Over-automating without human checkpoints. The best agentic workflows don't eliminate human judgment; they route it to where it matters most. Building escalation paths before you need them is much easier than adding them after an incident.
Build agentic workflows on Airtable
Airtable serves as the shared data layer that makes agentic workflows enterprise-ready: structured, auditable, and accessible to the whole team — so agents and humans work from the same source of truth, not separate systems.
Frequently asked questions
An AI agent is a single autonomous entity that handles a specific task. It perceives its environment, reasons, and acts. An agentic workflow is a coordinated process that typically involves multiple agents, tools, and humans working together toward a broader goal. Think of an agent as a skilled individual contributor; an agentic workflow is the team and the process around them.
They can, but the most reliable enterprise deployments don't. Well-designed agentic workflows include defined escalation points — conditions under which the agent pauses and routes to a human for a decision, approval, or correction. Full autonomy is a spectrum, and the right level depends on the stakes involved in each step.
Robotic Process Automation (RPA) follows fixed rules: if X, do Y, every time. It works well for stable, repetitive tasks but breaks when inputs change. Agentic workflows use AI reasoning to decide what to do next based on context, which makes them better suited for tasks with variability, exceptions, or judgment calls.
At minimum: a goal, relevant context (the data and documents the agent needs to act on), access to tools (APIs, databases, integrations), and a place to write results back. For enterprise use, the data layer needs to be structured, current, and shared so both agents and humans are working from the same source of truth.
The most common failure mode is an agent acting confidently on bad data: stale records, siloed systems, or missing context. The second is the absence of an audit trail, which makes it impossible to diagnose errors or prove compliance. Both problems have the same root cause, and the same fix: a shared, structured data layer that the agent reads from and writes to in real time.
