A shared system of record gives every team and AI agent a single governed source of truth to work from, instead of duplicating data across tools.
A system of record (SOR) is a singular destination for a specific type of data. For example, your ‘source of truth’ or system of record for customer information might be your customer relationship management (CRM) system. Meanwhile, your system of record for financial data might be your enterprise resource planning (ERP) system. These are systems your business trusts to be accurate. Business teams needing more context, however, may require a reconciled shared system of record that pulls from more than one core solution. This becomes critical when you’re building cross-functional workflows where humans and AI agents work together; accurate data needs to be available in real-time to hybrid human-agent teams.
A platform you can build on
Key takeaways:
  • A shared system of record is defined by who can see and act on data, not by where the data lives.
  • Data silos are more dangerous with AI agents in the workflow: agents act confidently on whatever they can see, even if it's outdated, so ungoverned data creates larger problems at machine speed.
  • Airtable pairs relational data with permissions and audit trails so human and agents work in one, governable platform.
What a system of record actually is
A system of record is the authoritative source for any given category of data. Most enterprises run on multiple systems of record, each scoped to specific functions. For example:
Today, most of these run as SaaS systems of record — cloud-based platforms — which makes the data easy to reach but not automatically easy to govern.
Traditional system of record vs. shared system of record
The difference between a traditional system of record and a shared one comes down to data ownership and visibility. Traditional SORs keep data, workflows, and permissions scoped to support individual functions. A shared system of record holds those same things in one governed place across teams. This means that both cross-functional teams and AI agents can act on data across systems, with confidence in the data integrity.
The underlying technology is mostly the same; a shared system of record pulls in data that lives in traditional SORs via APIs or Model Context Protocol (MCP), but the data becomes “shared” and — importantly — the shared system can log all agent and human interactions across data sources within the same record.
A CRM that allows marketing teams to read customer data is not a shared system of record. But it becomes one when sales, marketing, and support all read and write to the same governed record.
Why the shared version matters more as AI agents enter the workflow
When AI agents act on stale, siloed, or local data tied to a single team, it creates the same fragmentation as using disconnected tools or separate spreadsheets. Core data needs to be shared in real-time to operate at speed and scale. But you need to be confident in the data that agents access because they will act confidently based on what they can see, whether or not it’s current or missing related context. Data quality and integrity issues that used to surface slowly, caught by a person doing a gut check, now compound at machine speed and can go unnoticed until an agent has acted on them repeatedly.
The problem is that adoption of AI systems is outpacing oversight and governance, which can be a liability. McKinsey’s 2025 State of AI survey revealed that 88% of organizations use AI in at least one business function, but only 23% are scaling an agentic system somewhere within the enterprise. This means there’s a lot of individual team-based trial and error that isn’t widely visible. Gartner predicts that by 2027, 40% of enterprises may demote or decommission autonomous AI agents due to governance gaps that only surfaced after something went wrong in production. These errors can be difficult to troubleshoot unless workflows are built on a structured system of record, with a centralized agent audit log that shows what agents decided and why, and what the outcome of their action was — ideally alongside the actions of their human counterparts so that you don’t need to cross-reference multiple sources.
Another failure point is when AI lacks context. For example, when an employee uses Claude to boost their own productivity, Claude typically doesn’t have access to your organization’s shared knowledge — team conversations, documents, and data — to make decisions. Individual use leads to agent sprawl, where agents act on different knowledge sets, undetected. This is why Claude needs a system of record, and your company needs a shared audit log.
Signs your organization doesn't have a shared system of record
When teams are implementing AI solutions in silos, you’ll see:
  • Duplicate data entry across spreadsheets and tools
  • No cross-team visibility into status or ownership
  • Manual status updates that rely on someone remembering to post them
  • Dropped handoffs, whether between teams or between a person and an agent
  • No audit trail for who, or what, changed a record and when
Benefits of a shared system of record
Put simply: shared systems of record enable true human-agent collaboration through:
  • Better governance and permissioning: You control what a human or agent can see, and what they can change
  • Auditability: A traceable record of every change allows you to see what agents and humans did throughout a workflow, making it easier to troubleshoot if something goes wrong
  • Durable workflows: Work that persists across teams (instead of getting stuck in one chat thread, inbox, or exported spreadsheet) builds on and benefits from knowledge from past actions or results
  • Data consistency: Everyone, human or agent, works from the same current values instead of reconciling conflicting exports after the fact
When these work in concert, one person's or agent’s work picks up where another’s left off, without having to check with other systems.
Airtable as a shared system of record
Airtable is built on a structured, relational data model that makes it a reliable system of record for cross-functional teams. Airtable connects to many tools via API or MCP, allowing you to read and write back to other systems within the context of your workflows, reducing manual or duplicate data entry. You can also apply granular permission sets and log all agent and human interactions in a single record for auditing so that everyone, human or agent, can see your current state of business alongside details about what recently changed, and why. For a deeper dive into what that looks like for agent workflows, see how a system of record sets AI agents up for success.
Turn your operational data into a shared system of record
You don’t lack data, but you might be missing a governed place for data to live across cross-functional teams, where agents can expect to find a clear, accurate answer to a query. Airtable ties together your data and permissions, and provides an audit trail that traces both agent and human actions across a shared operational surface.
One platform for all your workflows
Frequently asked questions
A system of record is the authoritative source for a category of data, such as a CRM for customer data. A single source of truth aggregates and reconciles data pulled from multiple systems of record into one unified view for cross-team decision-making. In short, a system of record is where the data is logged and updated; a single source of truth is the combined picture built from several systems of record.
Technically, yes, if a team treats it as the authoritative source for a category of data. However, spreadsheets fall short as systems of record because they lack built-in permissions, audit trails, and validation, and they're easy to duplicate, fork, or overwrite without anyone noticing. That's usually the first sign an organization needs a real system of record rather than a shared file.
A system of record centralizes and governs the authoritative data, even if the data is pulled from other systems. A system of engagement is the day-to-day tool people (and increasingly agents) use to interact with that data, such as a dashboard, a form, or a chat interface. The two are meant to work together: the system of engagement is where work happens, and the system of record is where the results of that work stay accurate and auditable.
Common examples include a CRM as the system of record for customer data, an ERP as the system of record for financial data, and an HR system as the system of record for employee data. Each one is authoritative for its category, but scoped to support a single team or function.
Yes. A CRM is one of the most common traditional systems of record, as the authoritative source for up-to-date customer data. But a CRM alone is typically a single-team system of record, owned and used by sales. It only becomes part of a shared system of record when other teams, and any AI agents acting on customer data, can read from and write to that same governed data rather than working from their own exports or copies.
