AI has reached a point where raw capability is no longer the limiting factor. Today’s models can reason, generate, analyze, and take action across a wide range of business tasks, and they’re getting better every day.
The central challenge has shifted from whether businesses should adopt AI but how. How to make that intelligence actually work inside the business, across teams, tools, and processes.
This is where many efforts stall. Not because the AI isn’t capable, but because the technology is operating without structure governing its usage.
Agentic systems are what close that gap. They’re the operational layer that turns AI from something you experiment with into something you can rely on to get the job done. The teams pulling ahead aren’t just using agents, they’re taking a necessary first step: building the systems that allow those agents to work consistently, collaborate with humans, and improve over time.
What are agentic systems?
Agentic systems are AI systems made up of autonomous agents that can plan, make decisions, and take actions to achieve a goal with minimal human input. Instead of just generating outputs, they execute multi-step workflows, often coordinating with other agents and systems, to get real work done.
Agentic systems vs. AI agents
It’s easy to conflate AI agents with agentic systems, but the distinction matters.
An AI agent is a unit of capability. It can complete a task or automate part of a workflow. But on its own, it operates within a narrow context.
An agentic system is what allows that capability to scale, across multiple agents, teams, and organizations within a business. It coordinates how work gets initiated, what data the agent can access, how outputs are handled, and how everything connects back to the business.
A useful way to think about it: agents are tools. Agentic systems are the blueprint for how you use those tools together to build something meaningful.
What makes a system “agentic”?
A system becomes agentic when AI can pursue a goal end-to-end — planning steps, making decisions, and taking action — with the right context, coordination, and accountability built in.
That means moving beyond one-off interactions and toward workflows where agents have a clear role, access to the right information, and a defined place in how work gets done. Outputs don’t disappear into individual chat windows; they become part of shared processes that can be reviewed, measured, and improved.
What are the characteristics of agentic AI systems?
The strongest agentic systems share a few underlying traits. They pursue goals autonomously — planning steps, making decisions, and taking action across tools and workflows. They coordinate work across multiple steps (and often multiple agents), adapting as conditions change and improving over time through feedback.
To operate effectively inside a business, they also connect to structured, up-to-date data, make workflows visible so humans can stay aligned, and define how decisions are reviewed and escalated. Individually, none of these are new ideas — what’s new is applying them consistently to how AI actually executes work.
How agentic systems work
Most agentic systems follow a similar pattern. An agent is given a goal and determines how to achieve it — breaking the work into steps, pulling in relevant data from connected systems, reasoning through decisions, and taking action. Those actions might include generating content, updating records, calling APIs, or triggering downstream workflows.
But the output doesn’t live in isolation. It’s written back into a shared system where it becomes part of the workflow, allowing other agents or humans to continue the process. From there, humans can review, approve, refine, or escalate as needed, while the agent can iterate based on new inputs or feedback.
That interaction between output, system, and human oversight is what drives improvement over time. The value doesn’t just come from the model, but from the system that governs how work is executed, evaluated, and continuously refined inside the business.
Single-agent vs. multi-agent systems
Agentic systems don’t have to be complex to be effective, but as they scale, coordination becomes critical. Many teams start with a single-agent system focused on a specific task, like extracting structured data from documents or enriching CRM records. These are easier to evaluate and often deliver quick, visible wins.
As teams gain confidence, they begin to connect multiple agents together. One agent might gather and structure data, another analyzes it, and a third generates outputs or recommendations. At that point, the system starts to look less like a tool and more like a coordinated, multi-step workflow.
In practice, this often involves pairing powerful models with a structured system of record. For example, combining Claude with Field Agents in Airtable allows teams to orchestrate multiple steps across a workflow while keeping everything grounded in shared data and processes. This ensures each agent’s output builds on the last, and stays connected to how work actually gets done.
Challenges with agentic AI systems — and how to overcome them
Most challenges with agentic systems aren’t about the AI technology itself, and more from the gaps in how the system was designed and rolled out.
Unclear objectives
While it may be tempting to load an AI agent with several semi-related tasks, keeping things simple and scaling its output thoughtfully is the best way for the technology to add value.
When an agent doesn’t have a clearly defined goal, its output becomes difficult to evaluate and even harder to trust. The fix is simple in theory, but often missed in practice: tie each agent to a specific business outcome and define what success looks like upfront.
Unstructured data and disconnected tools
Agents perform best when they can access clean, current, and well-organized data. If they’re working with stale exports or fragmented systems, the quality of their output drops quickly.
This is why adopting relational databases vs. spreadsheets is so important. Before agents can perform well, the underlying data and workflows need to be structured and connected.
In addition to data cleanliness, making workflows visible is equally important. When processes are structured and shared, both humans and agents can operate within the same context. Agents should also be integrated with the systems your team already uses. This allows them to act on live data and move work forward, rather than operating in isolation.
Lack of orchestration across steps
As soon as workflows span multiple steps or agents, coordination becomes a challenge. Without clear sequencing and shared context, work gets duplicated, steps break down, and outputs don’t carry forward. Strong agentic systems define how work flows from one step — or agent — to the next.
Missing governance
Without clear oversight, trust breaks down. Teams need to know how AI agents are making decisions, where outputs are going, and when human intervention is required. This front-end effort helps build control and visibility into the system from the start, which thereby helps make the system more reliable. Furthermore, building a solid systems foundation can fuel more widespread adoption; thoughtful rollout can help teams feel grounded in this transformational technology, rather than swept away by the trend of the moment.
The goal is to make control and visibility part of the system from the start, which can get lost when mandates to adopt AI come fast and furious.
How to build agentic systems that teams can trust
The most effective teams don’t try to boil the ocean, as they say. They start with a single workflow and build from there.
Start with one repeatable workflow
Pick a process that already runs on a cadence and has clear inputs and outputs. The goal isn’t to automate everything at once — it’s to get one workflow running reliably end-to-end so you have something to build on.
Design agents as specialists, not generalists
High-performing systems aren’t powered by one all-purpose agent. They’re made up of focused agents with clear responsibilities, each optimized for a specific type of work. This improves quality and makes systems easier to scale.
Create shared views
One of the biggest shifts is moving agent outputs out of chat and into shared systems. When work is visible, it can be reviewed, improved, and reused across the team. An agent’s job isn’t finished when it produces an answer — it’s finished when that output can be used. Structure outputs so they plug directly into downstream work, whether that’s a report, a record update, or a triggered action.
Build systems that run without you
The real value of agentic systems comes from execution without constant oversight. Use triggers, schedules, and event-based automation so work continues even when no one is actively prompting the system.
Design for human review and escalation
Trust comes from visibility. Strong systems make it easy to understand what happened and why, especially when something goes wrong. That means building in checkpoints for human approvals, edits, and exception handling. Be clear and specific in your documentation on when a human needs to weigh in.
Measure outcomes rather than track activity
With plenty of AI mandates coming from the top down, it can seem like the goal is to maximize AI usage. But the ultimate goal of AI is to improve business outcomes. So focus measurement on what the system is unlocking for the team: speed, capacity, consistency, and impact. Some questions to consider include: How much faster did it accomplish a task? How much more volume was it able to handle? How consistent was its output? For example, did it produce the same result for the same requests every time? Did it learn from mistakes? Also, what was the impact on the team: were humans able to focus on more creative and strategic work?
Think like a system designer, not an operator
Your role isn’t to guide every step — it’s to design how the system runs. Define how work flows, how agents interact, and how outputs improve over time. The system handles execution; you refine how it works.
Build agentic systems with Airtable
Airtable provides the system of record that agentic AI needs to work in practice, bringing together structured data, connected workflows, integrations, and human collaboration in one place. Instead of individuals managing agents across scattered tools and conversations, teams can operate and experiment within a shared system where agents are coordinated, governed, and continuously improved.
Turn AI into a system your team can trust
Agentic systems are a combination of AI agents and the components around them — data, workflows, and governance — that allow them to do useful work. Agentic systems matter because while AI is capable of learning and acting, without the right systems, that capability doesn’t translate into consistent results.
Most AI tools generate outputs on demand. Agentic systems embed AI into workflows, connect it to real data, and enable it to take action as part of a broader process.
Start with a single workflow, make sure your data is structured and accessible, connect your core tools, and define how outputs will be reviewed and improved.
No. They change how work gets done. Agents handle structured, repeatable tasks, while humans focus on oversight, decision-making, and improving the system.
They’re what allow the system to improve over time. Feedback turns one-off outputs into a learning process that strengthens performance with each run.
Yes — and that’s where it becomes most valuable. When connected to existing tools, agents can operate on live data and take meaningful action within real workflows.
