A practical walkthrough for building AI systems that reason, plan, and act autonomously—from defining your workflow logic to connecting agents to your tools and data.
Agentic workflows are how AI stops answering questions and starts doing work alongside your team. Instead of generating a response and waiting for the next prompt, an agentic system reasons through a goal, selects tools, takes actions, evaluates the results, and keeps going until the task is done.
That shift matters for practitioners who've already hit the ceiling of conventional automation: rigid pipelines that break on edge cases, chatbots that can advise but can't act. Agentic workflows sit in a different category. They handle ambiguity, recover from unexpected states, and compound knowledge across steps rather than treating each step in isolation.
This guide is for people who already understand what agentic AI is and want to actually build something. It covers the architecture you need, the order to build it in, the governance safeguards that keep it accountable, and the failure modes worth anticipating before you hit them.
Key takeaways
  • Agentic workflows pair structured automation with AI reasoning. The agent decides which steps to run and when, rather than following a hard-coded sequence.
  • Clear system instructions, well-defined tools, and structured data are the foundation of any agentic system. Everything else builds on those three.
  • Airtable's flexible data model makes it a strong context layer for AI agents. Agents can pull structured records as inputs, push results back as outputs, and trigger workflows based on field changes.
What is an agentic workflow?
An agentic workflow is an AI-driven process where an agent iteratively reasons, takes actions, and adjusts based on results — without requiring a human to script every decision.
The core loop looks like this: the agent receives a goal (Trigger), thinks about what to do next (Thought), takes an action using one of its available tools (Action), and reads the result (Observation). Then it repeats. The loop continues until the goal is met or the agent determines it can't proceed without human input.
That's the structural difference from standard automation, which follows a fixed sequence of if/then logic. And it's different from AI chat, which reasons and responds but doesn't take action in external systems. Agentic workflows combine both: reasoning and action, across multiple steps, with the ability to adapt mid-process.
How agentic workflows differ from traditional automation
Traditional automation is a script, where every branch is pre-written. When something falls outside the expected cases — a missing field, an unusual request, a system that returns an unexpected response — the workflow either fails or routes to a catch-all that probably isn't the right answer.
Consider a customer support ticket workflow. A rules-based automation might escalate tickets with certain keywords, assign them to a queue based on category, and send a templated reply. That works well at volume, for predictable ticket types. But when a ticket doesn't fit cleanly into a category, or when the right answer requires reading the customer's account history, the automation produces the wrong output or none at all.
An agentic approach handles the same ticket differently: the agent reads the ticket, checks the CRM for account history, reviews relevant policy documents, drafts a response calibrated to the context, and flags for human review only when its confidence is low. The loop continues across tools and data sources rather than stopping at the edge of a pre-scripted path.
However, there is a trade-off. Agents are more capable but less predictable than deterministic workflows. For high-volume, identical processes where guaranteed consistency matters more than flexibility, traditional automation is still the right tool. Agentic workflows are better suited to tasks with branching logic, judgment calls, or edge cases that are difficult to categorize in advance.
Core components of an agentic workflow
Before you build anything, these five components need to be in place:
1. The LLM core. The model doing the reasoning — Claude, GPT-4o, Gemini, or another. The model determines how well the agent interprets ambiguous instructions, handles unexpected inputs, and generates usable outputs. Different models have different strengths; the right choice depends on your task type.
2. Tools. The APIs, databases, search functions, and code executors the agent can call. A tool is anything the agent can invoke to take action or retrieve information. Tools are what turn the LLM from a reasoning engine into a system that can actually do things.
3. Memory. Two kinds: short-term context (what's in the current session) and long-term storage (records and outputs that persist across sessions and can be read or written by the agent). Long-term memory is often underbuilt in early implementations and accounts for a lot of quality failures.
4. Orchestration layer. The system that coordinates the agent loop, routes between tools, handles errors, and manages the conversation history passed to the model. This can be a no-code platform or a code-based framework.
5. Governance. The rules, permissions, and audit trails that keep an agent accountable as it acts. This includes defining what data and actions each agent is allowed to touch, logging decisions and tool calls so behavior can be reviewed after the fact, and setting clear ownership for what happens when an agent gets something wrong. Governance isn't a layer you bolt on after launch; it needs to be defined alongside the tools and permissions themselves, or you end up retrofitting access controls onto a system that's already making decisions on live data. For a deeper look at setting these guardrails up, see Airtable's guide to AI agent governance.
6. Human-in-the-loop checkpoints. Approval gates at specific steps. The agent pauses, shows what it's about to do, and waits for confirmation before executing high-stakes actions. These aren't optional for production systems — they're how you prevent mistakes from propagating through your data.
Step 1: Map your workflow logic before you build
This is the step most people skip, and it's the one that determines how well the agent actually works.
Agentic workflows are only as good as the instructions and context you give them. A vague system prompt produces vague behavior. Tools attached without clear definitions produce wrong calls on which tool to use when.
Before writing a single line of configuration, work through the following:
  • Define the goal. What does the agent need to accomplish? Be specific enough that you could evaluate whether a given output meets the standard.
  • Identify decision points. Where does the agent need to make a judgment call? Where are the steps fixed and predictable? The judgment-call steps are where your system prompt needs to be most explicit.
  • List required tools and data. What does the agent need access to in order to complete the task? What does it need to read? What does it need to write?
  • Document edge cases. If you've run this process manually, you already know where things go wrong. Write those down so you can add them to the system prompt.
This step produces two artifacts: a system prompt and a set of tool definitions. Everything else in the build depends on those.
Step 2: Build your base workflows first
Before you add an agent on top, build the reliable sub-tasks as discrete, testable workflows.
A base workflow handles one thing well. “Pull all open records from Airtable where Status = In Review and format them as a list” is a base workflow. “Send a Slack notification when a record moves to Approved” is a base workflow. Each one runs predictably, accepts clear inputs, and produces clear outputs.
The agent then orchestrates which workflows to call and in what order, based on what it’s trying to accomplish. This separation keeps the system debuggable: when something breaks, you can determine whether the failure is in the agent's reasoning or in a specific workflow, rather than hunting through a single monolithic process.
Build the pieces, test them individually, then wire them together as tools the agent can call.
Step 3: Create the agent and connect your workflows as tools
With the base workflows in place, you can set up the agent itself.
Write the system instructions first. Treat these like onboarding documentation for a new hire: explicit about the role, explicit about constraints, full of examples for handling edge cases. Cover what the agent should do when it hits an error, when it’s uncertain, and when it should stop and ask for human input rather than proceeding. Vague instructions produce vague agents.
Attach the tools. Connect the base workflows and external tools the agent can call. Each tool needs a clear name and description — this is how the model decides which tool to use and when. “search_airtable_records” is more useful than “search,” and a description that explains what the tool returns is more useful than one that just names it.
Set the model and parameters. Choose the LLM and configure any relevant settings: temperature, max tokens, context window limits. These defaults matter more for some task types than others — generation tasks often benefit from slightly higher temperature; structured data extraction generally doesn't.
One pattern worth considering early: multi-agent systems. For complex goals, splitting the work across specialized agents—a researcher, a writer, a reviewer—often produces better results than loading everything onto a single generalist agent. Specialized agents are also easier to debug because failures are isolated.
Step 4: Test with real data and iterate
Testing with hypothetical inputs tells you very little. Run the agent on actual business data.
Evaluate outputs against what you'd expect a competent person to produce on the same task. When the output falls short, diagnose the failure before you change anything: is this an instruction problem (the system prompt didn't cover this case, or covered it ambiguously) or a tool problem (wrong data, broken integration, bad tool definition)?
Instruction problems get fixed in the system prompt. Tool problems get fixed in the tool or the data it connects to. Mixing up the two — updating the system prompt when the data is wrong, or patching the data when the instructions are missing — wastes time and produces fragile fixes.
Once the instructions are solid and the tools are reliable, try swapping models. Different LLMs have different strengths. A model that excels at structured extraction may underperform on tasks requiring nuanced tone. Running the same workflow with two or three candidate models, evaluated on the same test cases, often reveals a clear winner.
Common agentic workflow patterns
ReAct (Reason + Act). The agent reasons about what to do, takes an action, observes the result, and repeats. This is the most common pattern, and the right default for research tasks, data retrieval, and anything where the path forward depends on what earlier steps return.
Plan-and-execute. The agent creates a full plan upfront, then executes each step sequentially. This works better when the goal is well-defined and unlikely to require the plan to change mid-execution. It's less adaptive than ReAct but easier to audit.
Multi-agent orchestration. A supervisor agent delegates work to specialized sub-agents. Each sub-agent handles a specific function: research, writing, QA, data entry. This pattern scales well for complex workflows and makes failures easier to trace, since each agent's behavior is bounded by its scope.
The pattern you choose should follow the structure of the task, not the other way around.
Connect your agentic workflows to Airtable
Airtable gives AI agents a structured, queryable data layer to work with. Agents can read records as context, write results back as outputs, and trigger workflows based on field-level changes, making it a practical choice as the data backbone for agentic systems that need to operate on real business data.
Frequently asked questions
An AI workflow follows a fixed, pre-scripted sequence of steps. An agentic workflow lets an AI agent reason about what to do next based on context, choose which tools to call, and adapt when something unexpected happens. Agentic workflows are better suited to tasks with branching logic or edge cases that are hard to anticipate in advance. Standard automation is better for high-volume, predictable processes where guaranteed consistency matters.
No. No-code platforms like Airtable let you build agentic workflows through visual interfaces. Developer frameworks give you more control but require coding. If you're new to agents, start with the no-code approach — you can migrate to a code-based framework once you understand the patterns well enough to know what you need the extra control for.
Human-in-the-loop checkpoints are the most reliable safeguard. Most modern agent platforms let you add approval gates at specific steps: the agent pauses, shows you what it's about to do, and waits for confirmation before proceeding. Beyond that, write explicit constraints into your system instructions (“never delete records without confirmation”) and test on low-stakes data before deploying on production systems.
Structured, up-to-date context. In practice, this usually means: relevant records from your CRM, project tracker, or database like Airtable; a knowledge base of policies, SOPs, or product documentation; and tool definitions that tell the agent what actions it can take. The cleaner and more structured your data, the more reliably the agent will act on it.
A single agent handles the full task: reasoning, tool calls, and execution. A multi-agent system splits the work across specialized agents, where one researches, another writes, and another reviews. Multi-agent setups are better for complex workflows where different subtasks require different models, tools, or levels of autonomy. They're also easier to debug because failures are isolated to a specific agent rather than buried somewhere in a long single-agent trace.
