Every app you use, every transaction you make, every piece of customer feedback your team tracks runs on a database. Yet databases don't manage themselves—that’s the job of a database management system (DBMS).
A DBMS is the software layer between your data and the people or applications that need to use it. The system handles the way data is stored and organized, who can access it, and how to keep it consistent over time. Databases may have been invisible to most non-engineers in the past but today you don’t have to be technical or have coding skills to centralize, organize, and access your data. A DBMS today can look like an intuitive interface or dashboard that anyone can use to improve productivity and boost business outcomes.
What is a database management system (DBMS)?
A database management system is software that enables users to create, store, retrieve, update, and manage complex data in a structured way. Rather than storing information in disconnected files or spreadsheets, a DBMS organizes it into a database structure where relationships between data can be defined, enforced, and queried.
A DBMS system provides teams with reliable data access while maintaining data integrity, data security, and consistency. The goal is to eliminate data redundancy, enforce schema rules (think of a schema as a framework or plan for how data is organized), and ensure that multiple users or processes can work with the same data without conflicts.
Build a database system your way
Components of DBMS applications
The terms database and DBMS are sometimes used interchangeably, but a database is where information is stored and a DBMS is how you access that data. Several components of a DBMS work together to manage your data:
  • The database engine handles the core read/write operations and enforces rules set by database administrators.
  • A query processor interprets structured query language (SQL) and other data manipulation language (DML) commands, translating them into operations the engine can run.
  • The schema defines the structure of the database—what tables exist, what data types each field accepts, and how tables connect through primary keys and foreign keys.
  • Metadata about this structure is stored in a data dictionary.
  • Transaction management ensures operations follow ACID principles (atomicity, consistency, isolation, durability), while concurrency control prevents conflicts when multiple users access the same records simultaneously.
  • Access control and permissions determine who can read, write, or modify specific data—and backup and recovery tools protect against data loss.
Types of DBMS
Different workloads call for different database models. Increasingly, many business functions can utilize different database types via no-code interfaces, reducing reliance on developers. Here's an overview of the main types of database management systems.
Relational database management system (RDBMS)
The relational database management system is the most widely used type of DBMS. Data is organized into tables with rows and columns, connected through primary keys and foreign keys, and queried using SQL. Common relational database examples include MySQL, PostgreSQL, Microsoft SQL Server, Oracle Database, and IBM Db2. RDBMS platforms work well for structured data with clearly defined relationships—including financial transactions, customer records, and inventory management. Modern, cloud-based platforms like Airtable are built on a relational database, providing the structure you need without the technical expertise required for managing more traditional RDBMS platforms.
NoSQL databases
NoSQL DBMS platforms, also referred to as non-relational databases, were designed for unstructured data, semi-structured data, and workloads that don't fit neatly into rows and columns. These types of data include video, audio, images, PDFs, Word docs, emails, social media posts, and even sensor data from IoT devices). Subtypes of NoSQL databases include key-value stores, document databases (like MongoDB, which uses JSON-based storage), column-family stores (like Cassandra, built for large-scale distributed workloads), graph databases, which model data as nodes and relationships, and vector databases, which store data and search via high-dimensional vectors. NoSQL databases trade some rigidity for flexibility and scalability.
Other types of databases
There are other types of databases that are more specialized. These include hierarchical databases, which organize data in a tree-like structure with parent-child relationships; object-oriented databases, which store data as objects; NewSQL databases that combine relational structure with the horizontal scalability of NoSQL; and cloud-based or distributed DBMS platforms, which spread data across multiple nodes or regions, improving availability for real-time and large-scale workloads.
Advantages of using a DBMS
Manual data management doesn’t scale, and today companies handle vast and almost incomprehensible amounts of data. A DBMS platform provides you with many advantages, including:
  • Data integrity: Constraints, data types, and validation rules prevent bad data from entering the system and keep existing records consistent.
  • Reduced data redundancy: Centralizing data and using relationships eliminates duplication across files and systems.
  • Data security: Role-based access control, audit trails, and encryption allow enterprises to meet security and compliance requirements.
  • Reliable data retrieval: SQL and other query tools let users and applications rapidly pull the data they need.
  • Data consistency: Transaction management and concurrency control keep everyone working from a single source of truth, even across large, cross-functional teams.
  • Scalability: Modern DBMS platforms handle growing datasets and user loads through vertical or horizontal scaling.
DBMS examples
There's a wide range of DBMS software available, each suited to different use cases and data models. Organizations must consider their needs and integration with existing technology stacks.
MySQL and PostgreSQL are the most widely used open-source relational databases. MySQL is popular across web applications and cloud environments, while PostgreSQL adds support for advanced data types, including JSON and geographic data.
Microsoft SQL Server integrates with Microsoft's enterprise ecosystem, while Oracle Database handles high-volume transactional workloads in industries like finance and healthcare. IBM Db2 brings enterprise analytics and compliance capabilities.
On the NoSQL side, MongoDB is a document database suited for flexible, nested data structures, while Cassandra is built for distributed, write-heavy workloads at scale.
If you’re a non-technical team, the DBMS operating behind the scenes doesn’t necessarily matter, especially if your platform provides an easy no-code interface.
How does a database management system work?
When you interact with a database—pulling a report, adding a record, updating a field—you're not touching the data directly. The DBMS handles that work behind the scenes.
A DBMS processes requests using a few categories of instructions:
  • Data definition language (DDL) sets up the structure: what tables exist, what fields they contain, and what data types are allowed.
  • Data manipulation language (DML) handles the day-to-day work of retrieving and changing records—the queries that fetch a customer list or update an order status.
  • Data control language (DCL) manages who can do what, assigning permissions so the right people have access to the right data.
When multiple steps need to happen together, like moving inventory from one location to another, the DBMS groups them into a transaction. If anything fails partway through, it rolls everything back. This principle, called atomicity, is what makes databases trustworthy for business-critical processes. Concurrency control handles a related challenge: when multiple users update records at the same time, the DBMS prevents them from overwriting each other's changes.
How to build an effective DBMS
No matter which type of DBMS you use, a few principles apply:
1. Start with a clear data model. Understand what you need to store and how different entities relate before writing a query or building a table.
2. Design a clean schema. Normalize data to reduce redundancy, use appropriate data types, and define primary and foreign keys from the beginning.
3. Build in access control early. Define roles and permissions before users start working with the system—retrofitting data security is harder than building it in.
4. Optimize for your actual workloads. Read-heavy applications benefit from caching and indexing; write-heavy systems need efficient transaction processing.
5. Plan for backup and recovery. Test your recovery process regularly—not just when something goes wrong.
6. Choose a platform your team can actually use. Not every team needs a DBA-administered RDBMS. For operational teams, platforms like Airtable allow you to build a database without needing SQL knowledge. Users can create their base from scratch or build one using a pre-built template.
Trends in DBMS technology
A few shifts are shaping how database management systems have evolved over time.
Cloud-based and serverless databases make it easier to scale without managing on-premises hardware. Cloud computing has turned database infrastructure into an on-demand service, and most major DBMS platforms now offer cloud-native deployment options through providers like Amazon, Google, and Microsoft.
Multi-model databases reduce the need for separate specialized tools by supporting relational, document, graph, and key-value data within a single system.
Real-time data processing is also displacing traditional batch workflows, with more platforms built for low-latency queries and event-driven updates—important for apps where data consistency and speed both matter.
AI and machine learning integration is growing, both for automated query optimization inside the DBMS and for embedding AI capabilities directly into data workflows. Increasingly, teams want AI to act on structured data in real time—not just analyze it after the fact.
The rise of low-code and no-code platforms continues to broaden database access, allowing non-technical operational teams to build and manage data systems without relying on engineering resources.
Build a DBMS with Airtable
Traditional DBMS platforms provide power, but come with complexity. By contrast, Airtable is an AI-powered platform built on a relational database, allowing teams in marketing, product, creative, or operations to capture the data needed to power AI agent workflows within an intuitive, no-code interface.
For agents to produce useful output rather than generic output, they need structured data with explicit relationships, current state, and business context. With Airtable, the data is current, structured, and relational. Agents aren't guessing from documents or chat history. They're reasoning across the same operational reality that humans see.
Airtable provides both the structure and flexibility you need to build human and AI agent workflows.
The primary function of a DBMS is to provide a reliable, organized way to store, retrieve, and manage data. It acts as the interface between users (or applications) and the underlying data, handling query processing, transaction management, data security, and concurrency control.
DBMS software is used across every industry—from managing customer records and powering financial transactions to tracking healthcare data and supporting business intelligence. Traditional DBMS software is managed by technical engineering teams, but AI-native platforms like Airtable allow non-technical teams to bring database capabilities into everyday workflows to streamline and optimize processes.
A distributed database management system stores data across multiple physical locations—separate servers, data centers, or geographic regions—though users experience it as a single, unified database. Distributed DBMS platforms are designed for resilience, so they are always available and, if one server fails, the others pick up the slack. Most cloud-based database services use distributed designs to handle large-scale workloads.
