Most organizations have adopted AI. Far fewer have become AI-first. According to Airtable's research across 1,001 organizations, agent activity jumps 12× when organizations move from one-off prompts to agents embedded in workflows. The gap between using AI and running on it is the defining competitive divide of 2026. The companies on the right side of it are operating in a fundamentally different way: agents handling the repeatable, humans owning the strategic, with wins compounding over time.
Getting there isn't about deploying more tools. It's about building the infrastructure agents actually run on. This roadmap covers what that looks like in practice.
Why an AI-first mindset is a high priority
The window for treating AI as an experiment is closing. 88 percent of respondents report regular AI use in at least one business function, according to the Airtable Agent Ready Roadmap. While adoption is high, the report also finds that only about a third of companies that use AI are scaling it. That means the majority of companies use AI – but it's not improving how the organization operates.
Companies that move past that plateau now can compound that advantage every quarter, while those that don't find themselves competing against organizations that multiplied their operating capacity. An AI-first mindset is a strategic decision about the kind of organization you're building for the next five years.
4 Steps to become more AI-first
1. Structure your data before you deploy your agents
Fragmented data is a major reason AI deployments stall in the early stages of deployment. Agents can only reason from what they can access, and if your operational data lives across disconnected spreadsheets, siloed tools, and inconsistent formats, your agents will produce inconsistent outputs regardless of how capable the underlying model might be. The organizations furthest ahead in Airtable's research started with clean systems: structured data, defined workflows, and shared visibility across teams. That foundation is what makes everything else possible. Audit where your most business-critical data lives, identify the gaps and inconsistencies, and consolidate into a structured, shared layer before you add agent capability on top.
2. Connect agents to your core systems of record
The largest cluster in Airtable's research, 44% of organizations, sits at the "Assist" stage: where AI helps individuals with their own tasks, but remains disconnected from team operations. The leap to AI-first requires moving AI from personal tools to shared infrastructure.
The next step is connecting agents to the systems where work actually happens: your CRM, your project management layer, your campaign data, and your customer records, to name a handful.
This enables agents to read current state, reason across it, and write structured outputs back into live workflows without middleware or manual handoff. It's also what makes agent behavior persistent: agents that can access and update a shared system of record accumulate context over time rather than resetting with every session.
3. Build governance and human oversight into the architecture
Scaling AI is both a capability problem and a trust problem. The Agent Ready Roadmap found that at the most advanced stages, end-user resistance and governance gaps are the primary blockers. Organizations that build in governance from the start—role-based permissions, audit trails, human-in-the-loop checkpoints at high-stakes decision points—move faster in the long run because they don't have to retrofit controls after something goes wrong.
4. Measure AI-driven business outcomes, not AI activity
Most organizations in the early stages of AI adoption measure the wrong things: think of metrics like prompts run, hours saved, tasks completed. These metrics capture activity rather than business value. AI-first companies measure what changed for the business as a result of these new processes: revenue generated, cycle time reduced, capacity unlocked, decisions made faster. When the metric is business outcome rather than AI usage, the design question changes from "how do we use AI more?" to "what should agents own so humans can focus on what only humans can do?"
Guiding principles for AI-first companies
The organizations that made the most progress share a set of operating principles that go beyond specific tools or frameworks. Here are some of the clearest signs of success.
- Agents get assignments instead of queries: AI-first companies treat agents as digital teammates with defined responsibilities. Rather than waiting to react to queries, they have tasks to complete and accountability for those outcomes. Shifting from prompt-and-response to always-on delegation is the core architectural shift.
- Humans own the strategy while agents own the execution: At the most advanced stage, the division of labor is clear: humans define goals, set governance, handle exceptions, and adjust as needed. Agents handle the research, classification, routing, updating, and monitoring that previously consumed human capacity.
- Reliable infrastructure as a non-negotiable: Every structured workflow, clean data source, and defined governance rule makes the next round of agent deployments faster and more capable. AI-first companies treat this operational infrastructure as a strategic asset that appreciates over time, rather than a cost center.
- Acknowledgement that the bottleneck is organizational: The Agent Ready Roadmap finds that the biggest barriers to AI adoption are leadership alignment, data fragmentation, and change management. The organizations seeing the most impact treat all of the above as problems worth solving, with and without AI.
Today's infrastructure, tomorrow's advantage
Becoming AI-first isn't a single decision, but rather a series of architectural ones made stage by stage. The true AI-first companies prioritize structured data, governed workflows, shared visibility, and a system of record where humans and agents work side by side from the same sources of truth.
Airtable is built to be that foundation: an AI-native operational platform where the infrastructure you put in place today develops into the organizational capability that defines your next chapter.
Find out where your organization stands, and what to build next.
Being AI-first means that AI agents are embedded in how your organization actually operates, rather than being available to individuals as personal productivity tools.
An AI-first company structures its data, designs workflows where agents handle defined steps, and builds the governance infrastructure that makes it safe to hand agents real responsibility. The best AI-first benchmark is whether the organization runs differently because of it: faster decision-making, fewer manual handoffs, and compounding capability that improves over time rather than resetting with every prompt.
The mechanism is capacity, speed, and compounding context. When agents handle repeatable tasks—research, classification, routing, record-updating, exception-flagging—human capacity can be redirected toward decisions that require more nuance. When agents are embedded in workflows rather than invoked one at a time, AI activity multiplies; Airtable's research shows a 12x jump. Furthermore, when agents operate from a persistent system of record, each interaction builds on the last rather than starting from zero. The cumulative effect is an organization that scales output without proportionally scaling headcount.
The most consistent barriers are organizational, not technical. Airtable's research surfaced four recurring blockers: leadership hasn't aligned on a mandate or starting point, data is too fragmented for agents to reason reliably from, teams are drowning in tool sprawl without a clear path from departmental AI use to shared infrastructure, and governance gaps make stakeholders reluctant to give agents responsibility for business-critical work. The organizations that break through these barriers share a common approach: they start with data structure, establish a clear first workflow to hand to agents, and build governance into the process at the beginning, rather than treating it as a constraint to manage later.
There's no fixed timeline, but Airtable's Agent Ready Roadmap identifies distinct maturity stages. Organizations that adopt AI most effectively share a common pattern: they start with data structure, establish one governed workflow to hand to agents, and build from there. The compounding effect is real — each structured workflow and clean data source makes the next deployment faster. For most organizations, meaningful progress is visible within a quarter when the starting point is right. Full transformation is a multi-year architectural commitment.
It's the prerequisite everything else depends on. Agents can only reason from what they can access, and fragmented data — spread across disconnected spreadsheets, siloed tools, and inconsistent formats — produces inconsistent agent outputs regardless of model capability. Airtable's research found that the organizations furthest ahead started with clean systems: structured data, defined workflows, and shared visibility across teams. Data infrastructure isn't a technical detail to solve after agents are deployed, but a foundation that determines whether agents can do reliable work at all.
