Use Case
A Gantt chart that rules the schedule
A custom architectural millwork manufacturer migrated its project and job scheduling from a legacy spreadsheet-based tool to Airtable, using Airtable's Gantt chart to manage operational timelines and dependencies. Project managers now have visual scheduling that replaced prior tool workarounds and, in their own words, effectively runs the schedule.
The problem
A legacy spreadsheet tool forced constant scheduling workarounds and gave project managers no visual way to see timelines and dependencies. Project and production planning stayed disconnected, so every schedule change meant manual reconciliation.
What they built
Operations and Project Management moved job and project scheduling into Airtable and made the Gantt chart the primary planning view. Timelines and dependencies now live in one shared, visual source of truth.
The outcome
Project managers say the Gantt view now runs the schedule. Project and production planning share one consolidated view, and the old tool's limitations no longer shape how work gets planned.
Build out this use case
Project Scheduling & Gantt Planning
Plan every project on an interactive Gantt timeline with phases, owners, and task dependencies. A portfolio dashboard rolls up project health and contract value, and automations keep the schedule alive — starting the next task when one finishes and flagging downstream work when a date slips.
Project Scheduling & Gantt Planning - Schedule (Gantt) view
How it works
From workaround-heavy scheduling to one Gantt view
Copy the templates
Start from the project resource management template above for timelines and dependencies, and add the project portfolio management template for a rollup across active jobs.
Migrate timelines into the Gantt view
Move existing project and job timelines into Airtable's Gantt chart so dependencies render visually instead of living in disconnected spreadsheet tabs.
Align project and production planning
Link project records to the operational teams and jobs they affect so schedule changes in one place are visible everywhere else.
FAQ
Frequently asked questions
The prior spreadsheet-based tool forced constant workarounds and never delivered effective visual scheduling. Airtable's Gantt chart gave project managers a native, visual way to manage timelines and dependencies.
Operational timelines and dependencies for jobs and projects, giving project managers one visual reference instead of reconciling separate spreadsheet-based schedules.
The Gantt view keeps project and production planning in the same system, so operational teams see the same timeline project managers are working from.
Scheduling effectiveness improved enough that project managers describe the Gantt view as the tool that runs the schedule, replacing the ad hoc workarounds the prior tool required.
Not for the scheduling workflow itself. The account is exploring AI elsewhere for document-heavy work, separate from this Gantt-based planning use case.
