Use Case
A virtual office for every department
An in-house production unit runs Airtable as a company-wide virtual office: tasks, assignees, deadlines, and calendars coordinated across the organization with day and hour views in interfaces. Teams get coordinated timelines and a financial calendar to hit deliverables during seasonal staffing peaks that run from spring through late fall.
The problem
Coordinating tasks, deadlines, and calendars across every department was difficult without a shared system, especially during the seasonal staffing peak that runs roughly from spring through late fall when the organization brings on guest and seasonal staff.
Two-way sync with Google Calendar, particularly around deletions, never worked cleanly, and scheduling at the minute level was not something base views handled well. Getting the whole company to adopt one shared system took real training and cultural change.
What they built
Operations, Programming, and Production teams built an Airtable virtual office that assigns tasks, tracks deadlines, and coordinates calendars company-wide, with day and hour views built into interfaces for teams that need finer granularity.
A financial calendar sits alongside the task system to keep deliverable milestones visible, and the base extends to manage seasonal and guest access for the staffing peaks each year.
The outcome
Teams now work from coordinated timelines instead of separate department trackers, which supports on-time deliverable execution even during the busiest stretches of the year.
Visibility during seasonal peaks improved because the same base that runs day-to-day task management also tracks the financial calendar milestones that matter most when staffing is stretched thin.
Inside the solution
Company-Wide Task and Project Management
Project & Portfolio Management
  • Task assignment and deadline tracking
  • Company-wide calendar coordination
  • Financial calendar for deliverable milestones
  • Minute-by-minute scheduling via interface calendars
  • Lack of two-way Google Calendar sync
  • Difficulty scheduling at minute-level granularity
  • Cultural adoption and training challenges
  • Managing seasonal and guest access
  • On-time deliverable execution
  • Coordinated timelines across departments
  • Improved visibility during seasonal peaks
  • Operations
  • Programming
  • Production
  • Google Calendar
Build out this use case
Company-wide task and project management
Run your whole company from one virtual office: every department's tasks, deadlines, and minute-level day and hour calendars live beside a financial calendar of deliverable milestones, so seasonal peaks never break the timeline. Automations onboard seasonal and guest staff, flag at-risk projects the moment a task blocks, and email a Monday digest, while native AI drafts task briefs, status updates, and onboarding checklists.
Company-wide task and project management - Overview dashboard
How it works
From department silos to one virtual office
Copy the templates
Start from the project resource management template above for timelines, add the kanban board template for department task views, and the remote team hub for company-wide coordination.
Build the financial calendar
Layer a financial calendar of deliverable milestones on top of task records so seasonal deadlines are visible alongside day-to-day work.
Add interface calendar views
Build day and hour views in interfaces for teams that need finer scheduling granularity than the base view provides, and sync what you can to Google Calendar.
FAQ
Frequently asked questions
Every department's tasks link to the same deadline and calendar structure, so a company-wide view rolls up individual assignments without requiring departments to give up their own task lists.
It tracks deliverable milestones tied to the organization's revenue and staffing calendar, layered on top of task records so finance-relevant dates stay visible alongside operational deadlines.
Interfaces provide day and hour views for teams that need that granularity, though the team notes native base views alone do not support true minute-by-minute scheduling.
Seasonal and guest access is managed within the same base, so temporary staff brought on during peak months get the access they need without a separate onboarding system.
Not for task and calendar coordination itself. The account is separately evaluating an AI-generated hours-tracking application to monitor workload, and this structured task data is exactly the foundation that effort would build on.
