Project managers are critical to cross-functional projects. But it’s a difficult job to align the team, ensure timelines stay on track, mitigate challenges, and keep stakeholders informed, even with the help of project management software. Modern platforms help break projects down into their smaller moving parts and provide transparency across the team, but they’re most effective when you’re taking full advantage of your solution.
Today, AI agents are changing what a day in project management looks like. Many of the manual status updates, task assignments, dependency tracking, and team follow-up can be handed off to your system, giving you time back to really assess what’s working and what isn’t.
This guide covers what AI agents for project management do, where they add the most value, and how to approach adopting them in a way that works for your team.
What are AI agents for project management?
AI agents can perceive their software environment, reason about it, and take actions to complete goals—with little or no human input. Whereas chatbots wait for a prompt and then return a response, AI agents monitor conditions, make decisions, and execute multi-step tasks, within the guardrails you set.
In the context of project management, AI agents go beyond simpler automation to sit inside your project management workflows and do things like watch for overdue tasks, flag risks before they become blockers, generate meeting notes, or redistribute work when team capacity shifts. They operate in real-time and adjust as needed, without waiting for a summary report.
The underlying technology draws on machine learning and natural language processing, which allows agents to understand context, interpret instructions, and improve over time using historical project data.
Meet your new project management BFF
Key capabilities of AI agents in project management
The way AI agents function varies by platform and use case, but here are a few ways they can broadly help your project management workflows.
  • Project planning: Before the project even begins, you can feed an AI agent project goals, specifications, and past performance history on similar projects to recommend the best course of action.
  • Task automation and assignment: Agents can create tasks from action items in meeting notes, assign work based on team capacity, and set due dates based on project timelines.
  • Risk management: By monitoring task dependencies and project milestones, AI agents can spot problems before they escalate. If a critical dependency is at risk of slipping, the agent can surface the issue and suggest mitigation steps.
  • Resource allocation: AI agents can analyze workload across team members and flag imbalances—whether someone is over-capacity or a task is sitting unassigned too long. Some agents can rebalance work within defined rules.
  • Real-time summaries and reporting: Agents can generate summaries of project status, compile updates from across a workflow, and prepare stakeholder-ready reports for project manager approval and adjustment.
  • Workflow automation: Beyond individual tasks, agents can manage entire workflow sequences: triggering approvals, sending notifications, updating dashboards, and moving work through defined stages.
  • Prioritization: Using context from project data, deadlines, and dependencies, agents can help teams prioritize what to work on next. This is especially useful during sprint planning or when scope changes mid-project.
Traditional project management tools vs. AI agents
Many traditional project management software tools (think: Jira, Asana, Trello, and ClickUp) are built around structure: boards, issues, task management, and reporting. They may offer automation and some level of AI capabilities, but typically within the confines of the tool. Other AI tools, such as Microsoft Copilot operate best within specific ecosystems, like Microsoft 365.
Overall, AI agents thrive best when operating within unified solutions that both connect and store data across systems, like Airtable, providing the agent(s) with bi-directional data syncs and real-time context so that it can make the best and most relevant decisions using data collected across platforms.
AI agents don’t replace traditional project management tools—they only enhance their effectiveness. For example, where a traditional project management tool notifies you when a milestone is approaching, an AI agent might notice that the tasks required to hit that milestone are behind, send an automated notification to the right team members, and suggest which items to prioritize to get back on track. Consider whether AI-assisted features are add-ons or built natively into core workflows.
Examples of AI agents in project management
AI agents can assist across a variety of project management scenarios. Consider where your team might benefit most by adding an AI agent to your workflow. Here are a few ideas:
  • Agile and sprint planning: An AI agent can analyze a backlog, factor in team capacity, and recommend a sprint scope. During the sprint, it tracks progress and flags when items are at risk of not making it to completion.
  • Meeting notes and action items: After a project sync, an agent can generate a summary of decisions made, capture action items, and create corresponding tasks in the project management tool.
  • Cross-team dependency management: For complex projects with multiple teams, agents can monitor dependencies across workstreams and alert the right team members when upstream work is delayed or adjust dates as needed.
  • Stakeholder reporting: An AI agent can pull current data from dashboards, generate summaries tailored to the audience, and distribute them on a defined schedule.
  • Operations management in regulated industries: AI agents can help in industries like healthcare, where regulations and clear rules apply. AI agents can monitor and adhere to compliance steps—routing approvals, tracking documentation, and flagging when required steps are missed.
Benefits of AI agents in project management
AI agents can help project managers further optimize their processes. There’s no need to hand everything off to an AI agent, but consider where agents might help and the benefits you stand to gain.
Less time spent on repetitive tasks
Updating statuses, sending follow-up reminders, and compiling reports are necessary but often tedious and time-consuming responsibilities. Project managers can pass these off to an agent so that they don’t have to micromanage every task and subtask within a project.
Earlier risk detection
Project managers can’t babysit every initiative and are often caught up in meetings, making it easy to miss a key handoff. Meanwhile, AI agents can monitor projects continuously and catch issues before the end of the day or week.
Consistency across complex projects
Complex cross-functional projects often involve both high-level and detailed tasks. For example, a promo video may be one of many key deliverables, but the steps required to complete the video involve a specific team and workflow. Agents can help enforce process steps and keep workflows moving, even when no one is actively watching.
Application of historical data
AI agents learn from historical project data to improve estimates, flag recurring bottlenecks, and make resource allocation recommendations based on what worked in the past. This is especially helpful as tenured employees move on and new employees are onboarded, ensuring that institutional knowledge carries on through concrete data and results.
Faster, more accurate stakeholder communication
AI agents within modern platforms generate active summaries from live data, which means that stakeholders have access to accurate, real-time data at any stage of the process, allowing them to act and shift direction without waiting for manual weekly, monthly, or quarterly reports.
Challenges of AI agents in project management (and how to resolve them)
Any new technology comes with a learning curve, and using AI in project management is no different. Here are some common challenges and how you can handle them.
Data quality and structure
AI agents are only as useful as the data they have access to. If your project data is scattered across spreadsheets, email threads, and disconnected tools, agents aren’t set up for success. Consolidating tools into an AI-native workflow platform helps agents perform to the best of their ability.
Team adoption
Every new software or process change requires some change management or training. Usually, this is just about the learning curve, but when it comes to AI, teams may be skeptical of tools that have the capacity to act autonomously, especially when taking over workflows they've previously managed themselves. Start with small, low-stakes automations so that your team can see the value and begin to trust the outcomes.
Over-automation
There’s mixed advice out there about applying AI to high-impact initiatives versus easing in with low-stakes projects. That’s up to you, but not everything should be automated—tasks that require nuanced judgment, sensitive stakeholder communication, or significant context about organizational dynamics are better handled by people. AI agents are designed to streamline the more mechanical parts of project management.
Integration complexity
AI agents that can't connect to the tools your team already uses will create additional work instead of less. Look for platforms where AI is native to your workflows—not bolted on through a third-party connector like Zapier—so that agents have access to real-time context and data.
Will AI agents replace project managers?
No, AI agents are not meant to replace project managers. Instead, AI agents can help manage many tasks that project managers are traditionally responsible for and influence strategic decisions. What they can’t do is account for the nuance of navigating stakeholder dynamics, organizational politics, and making judgment calls under ambiguity. Project managers are often diplomats, motivating teams to work together to reach a common goal. Those responsibilities remain firmly in the realm of human project management.
AI agents primarily represent a shift in how project managers spend their time. While traditionally organized and detail-oriented, the best project managers are also strategic— allowing AI agents to run workflows at scale, catch risks they might have missed, and offload tedious tasks so they can see the bigger picture.
The key is to look for tools like Airtable that facilitate human-agent collaboration.
How to get project managers to adapt to AI agents
Even when there’s a clear business case for AI agents, it can be overwhelming to get started or hard to stop what you’re doing to set your AI agent up for success. Here are some ways to implement and adapt to working with AI agents:
  • Start with pain points. Consider what takes the most time, but adds the least value. Then, think about how AI agents can be a solution to that specific problem. Automating tasks that the team doesn’t enjoy is a great starting point.
  • Keep some control. While agents can act autonomously and take over some decision-making, start slow so that you can understand what the agent is doing, maintain the bandwidth to review its outputs, and keep the ability to override it. Autonomy with oversight, rather than full automation, is the best starting point.
  • Use templates to lower the learning curve. Pre-built workflow templates make it much easier to get started with AI-powered project management. Rather than building from scratch, teams can start with a structure and customize as desired.
  • Measure the benefit to you. Beyond business goals, track the time you save on repetitive tasks, the reduction in meetings, or note the project risks that were flagged early. These are wins you can share with the business and also show the tangible value of implementing AI agents within your workflows.
  • Save time to provide feedback. Sometimes it seems like adopting AI means you can race ahead to the next thing. But when first adapting to AI agents, you need to build trust in the agent’s decisions. You essentially act like a personal manager. Build in a process for capturing feedback and improving the agent's behavior over time.
How DEPT unifies data and accelerates work with AI
DEPT is a technology and marketing services company that works with renowned brands like Google, KFC, and eBay. The agency staffs a large global team to build cutting-edge digital experiences and deliver best-in-class creative work.
DEPT adopted Airtable to manage production workflows. “When you’re delivering 120 shoots a year, with thousands of assets and a globally distributed team, the stress of managing everything through Slack and spreadsheets becomes overwhelming,” says Toby Baker, production director at DEPT.
Beyond centralizing operations within a unified platform, DEPT identified a use case where AI could help with projects. The team feeds project requirements into Airtable, and AI recommends the best influencers for campaigns—within minutes.
Build project management AI agents with Airtable
Airtable provides a platform where humans and agents can collaborate seamlessly. Both humans and agents can operate on the same data, see the same state, and stay accountable to the same goals.
Companies can deploy thousands of agents within their apps in minutes. The platform is designed so that workflows and data are centralized, giving agents the context they need to analyze thousands of records, generate summaries or images, extract insights, search the web, and continuously execute multi-step workflows in the background. Project management teams can also build custom agents to handle any other tasks they need.
Ready to get started? Put Airtable AI agents to work for you.
